1998 Oldsmobile Silhouette cooling system
170,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMELESS48
my friends sillouette, heats up too hot and then drops down to too cool, He changed the leaking water pump and somewhat flushed the system. when it heats up too much the heater in the van gets very hot, but when it drops down it does not throw any heat, Got any ideas on this---thanx -Rick
Jan 16, 2010 at 12:19 PM
BILLYMAC
  • 2,204 POSTS
Hi
this is caused usually by two things.thermostat failing.
or air in the system. this eng has a bleeder near the tstat housing run the eng until norm operateing temp. loosen this bleeder when pure coolant is flowing system is bled..
Jan 16, 2010 at 12:33 PM
