1997 Oldsmobile Silhouette won't start
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM GEORGE
I replaced the intake manifold gaskets, plugs, plug wires and front o2 sensor.
now van won't start.
It turns over and that's all.
I recently learned the I should have checked the fuel flow through the rail before replacing the upper manifold
Where and how do I start looking for the problem
I need this van to look for a job. I hope you can help me out.
Apr 9, 2009 at 11:29 AM
  • 75,988 POSTS
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 9, 2009 at 11:33 AM
