1997 Oldsmobile Silhouette intake manifold
17,900 MILES • 6 CYL • FWD • AUTOMATIC
WILLIAM GEORGE
What are the new torque specs
Apr 8, 2010 at 1:37 AM
MATT21191
[quote:e4e4740bc1="william george"]Engine Mechanical problem
1997 Oldsmobile Silhouette 6 cyl Front Wheel Drive Automatic 179,00 miles
What are the new torque specs[/quote:e4e4740bc1] William, hi im new to the forum and i also have the same yr van as you. does yours have a 3.4 ? im having lifter issues and missfire issues. have you had these before with yours ? thanks, matt
Apr 9, 2010 at 1:01 AM
WILLIAM GEORGE
Yes I have a 3.4 with misfire reading. PO300 reading
i have the lifters ready to install, but I need the new torque specs first.
While I have the engine apart, I plan to get the injectors tested.
If I find something else wrong after I replace the lifters,
I'll post it.
Will
Apr 10, 2010 at 9:40 AM
