1997 Oldsmobile Silhouette Battery
150,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMVASEK
How do you install a new battery?
Jul 28, 2009 at 8:34 AM
  • 75,988 POSTS
Remove the negative cable then the positive cable-reinstallation connect the positive cable then the negative cable then your done. Be advised disconnecting the battery causes the computer to lose it memory and requires a computer relearning process
Jul 28, 2009 at 8:45 AM
