1997 Oldsmobile Silhouette Battery
1997 OLDSMOBILE SILHOUETTE
150,000 MILES • 6 CYL • FWD • AUTOMATIC
JIMVASEK
How do you install a new battery?
Jul 28, 2009 at 3:34 PM
Remove the negative cable then the positive cable-reinstallation connect the positive cable then the negative cable then your done. Be advised disconnecting the battery causes the computer to lose it memory and requires a computer relearning process
Jul 28, 2009 at 3:45 PM
