1995 Oldsmobile Silhouette
MARGJOHNS2006
1995 Oldsmobile Silhouette V8
i have a 1995 olsmobile silhouette 3.8 engine I start it up it runs for 8 seconds shuts down if you continue to crank no injector pulse any ideas?"
Oct 23, 2009 at 6:05 AM
DOCFIXIT
  • 18,828 POSTS
Is there voltage to injectors on pink wire?check PCM for codes see diagram jumper between term. A and B MIL will flash so flash pause flash, flash is 12
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_204.jpg
if you have 16 pin then need dealer to code.
Oct 23, 2009 at 8:08 AM
