1997 Oldsmobile Regency Timing
140,000 MILES • 6 CYL • FWD • AUTOMATIC
LAUREL63
I need to set the timing on a 1997 oldsmobile regency, 3.8 L engine. I repaired the heads for a blown gasket, and replaced the timing belt. The car tries to start but won't. Thanks for your help. L Williams
Mar 14, 2010 at 3:05 PM
  • 75,988 POSTS
Did you put engine no.1 piston on its compression stroke/TDC and line the cam and crank?
The ignition timing is not adjustable its electronically controlled.
Mar 14, 2010 at 4:24 PM
