1995 Oldsmobile Regency miss
TOMMYGEE
  • 1995 OLDSMOBILE NINETY-EIGHT REGENCY
  • 6 CYL
  • FWD
  • 170,000 MILES
Engine misses when load not applied. Have changed plugs and wires and even (based on diagnositc testing) changed the intake manifold.
Sunday, February 8th, 2009 AT 1:45 PM
  • 109,867 POSTS
Hi:
Have you scanned the computer for codes? Many parts stores will scan it for free, so there is no out of pocket expense. Try that and let me know if you find anything.
Saturday, February 21st, 2009 AT 1:25 PM
TOMMYGEE
Thanks for your response. Yeah, I did have it scanned, that's where I got the apparently false info that my intake manifold was cracked. It's kind of baffeling. I did have two guys suggest that it could be just a fuel filter, so that's what I'm doing now.
Saturday, February 21st, 2009 AT 7:37 PM
  • 109,867 POSTS
Hi:
A fuel filter won't hurt, but you said it misses when it's not under a load. I would think a miss under a load would be more to identify a lack of fuel.
Have you checked for vacuum leaks? Check the EGR valve to make sure it's not stuck. That would cause a leak and a miss.
Let me know. Also, if you want to check fuel pressure, let me know and I'll provide the directions for you.
Saturday, February 21st, 2009 AT 8:49 PM
