1990 Oldsmobile Regency Crankshaft Sensor Repair
RJPRAY
Engine Performance problem
1990 Oldsmobile Regency 6 cyl Front Wheel Drive Automatic
Ok, I have determined that I have to replace my Crankshaft Sensor on my 1990 Oldsmobile Regency 98, 6cyl 3.5l engine.
Now this is where we run into another problem... How do I get behind the puller or remove the pulley?
Thanks for your help!
Apr 23, 2009 at 12:37 PM
BILLYMAC
  • 2,204 POSTS
hi, if you have air avail and a very good impact wrench ,not a big prob..but if you don,t then the bolt that holds this pulley on is extremely tight. and the prob is there is no way to hold the crank..you have to remove that pulley if you have probs doing that write back and i will help. thanks billymac
Apr 23, 2009 at 12:53 PM
