1990 Oldsmobile Regency
225,000 MILES • 6 CYL • FWD • AUTOMATIC
JONAMY1998
While driving down the road and turn to the left a little at highway speeds I have a bad vibration in the front left and when I straighten the wheel out it goes away. It only happens while turning left.
Jan 21, 2009 at 2:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect worn wheel bearings or ball joint. Raise vehicle and support safely. Try to wiggle wheel. If wheel has play in it, replace worn component. Most of the time, worn wheel bearings are accompanied by loud noise which goes away by turning the wheel.
Thanks for using 2CarPros.com!
Jan 21, 2009 at 3:49 PM
