91 cutlass supreme 3.1 v6...problem...car starts and runs good for a short period ... acting like its out of gas..3/4 tank at this time..i hear the fuel pump buzz when i 1st tun the key on.. i have cleaned the mass air sensor and did basic checks... when i spray a little start fluid in the air box it fires for a second...i dont have a fuel pressure gauge but i have opened the fuel schrader on top of engine.. i only get a little spurt of gas even with the key on..what do you think???t ...regulator ,filter or pump how do i test regulator??? if the pump is bad is there a access under the rear seat bottom???? i have made a small donation..thanks
Mar 6, 2007 at 1:03 PM
