wierd sound like running water? water pump or oil pump?
OLDSMOBILE
SUMITUP
  • 5 POSTS
Ok here it goes....
92 achieva 3.3l v6. 131k
I bought this car about 2 months ago and love it, but there are a few problems....
I think this car had been sitting for a long time becuse it was pretty dirty, I had the oil changed and tried to clean her up the best I could.
Problem is oil pressure goes from 30-70, with no performance problems, but the check oil light comes on spiraticaly.
Problem is the "low coolant" light came on 2 weeks ago so I put in about 1/2gal of antifreeze, I didnt have any leaks, so I checked my Oil and it seemed OK. Now this week I hear what sounds like my water pump grinding, but only occassionaly. Now today I hear a sound like water running when I started it and it contined as I accelerated.
My temp gage never went above 160.
What do you guys think? Could the sound of running water be a problem with my radiator?
Thanks
Aug 27, 2007 at 12:48 AM
JSCZYNSKI
  • 48 POSTS
[quote:5215db1631="sumitup"]Ok here it goes....
Thanks[/quote:5215db1631]
I'd have the vehicle pressure tested. Most places charge like $40 to have it pressure tested. off the top of my head it sounds like you have an internal coolant leak which may mean you need a new head gasket.
Oct 12, 2007 at 12:58 AM
