1992 Oldsmobile Ciera White Smoke
OLDSMOBILE
BABYBLUES80
i have a 1992 oldsmobile cierra. it is blowing out a lot of white smoke from the tail pipe. when i am sitting at idle the smoke gets even worse. it smells heavily like antifeeze. HELP
Jan 27, 2007 at 9:57 AM
MATHIASO
  • 1,209 POSTS
you may have coolant entering the combustion chamber. check the coolant level to confirm that and perform a pressure test. This may be the head gasket.
Jan 27, 2007 at 10:06 AM
BABYBLUES80
thank you. i will try that.
Jan 27, 2007 at 11:51 AM
MATHIASO
  • 1,209 POSTS
you're welcome :)
Jan 31, 2007 at 2:13 AM
Suggested Repair
Check the coolant level and perform a cooling-system pressure test. Coolant entering the combustion chamber, possibly from a failed head gasket, can cause white exhaust smoke that smells like antifreeze.
Conversation Summary
The owner of a 1992 Oldsmobile Ciera reported heavy white smoke from the tailpipe, worse at idle, with a strong antifreeze smell. The expert said coolant may be entering the combustion chamber and recommended checking the coolant level and performing a pressure test, noting a possible head gasket problem. The owner agreed to try those checks.
