Voltage is to high
CENTURY76
  • OLDSMOBILE
I have a 1986 oldsmobile calias, when the car is at idle the volt meter runs at 13 which is normal, but when ever I hit the gas the volts jump to 16 or 17 which I know its to high. I was told it was the volt regulater. But I believe its built in to the altenator. What do you guys think?
Tuesday, August 15th, 2006 AT 11:07 PM
MIKEYBDMAN
  • 623 POSTS
The system operating voltage for your vehicle is 13.5-16 volts. If your gauge is reading 17, I would have the altenator tested to see if your gauge is incorrect, or if the altenator is actually putting out 17 volts. If it is, replace it.
Wednesday, August 16th, 2006 AT 4:41 PM
