Vehicle knocking at initial startup (2001 olds bravada)
2001 OLDSMOBILE
KCFAN22
In the morning when I first start my 2001 bravada it will knock for approximently 5 minutes and then run fine I thought it was the Oil pump but the gauge is right in the middle so I am not sure if that is it or not. It was doing it right before I changed my oil and after I changed the oil the knocking stopped until the oil was approx 1,500 miles old and then started it again. Could I assume it is the oil pump even though the oil pressure gauge seems ok?
Sep 25, 2007 at 4:23 AM
  • 31,937 POSTS
Hi there,
i would not trust the gauge in the car, have the oil pressure checked with a master gauge on cold start up and hot run. make sure oil and filter are correct, better to check now then have very expensive repairs around the corner.
Mark (mhpautos)
Sep 25, 2007 at 10:41 AM
