transmission
OLDSMOBILE
RELTNEE
I have a 2000 olds bravada,4.3engine and a 4l60e transmission, 125000 miles onthe car. I have no reverse when i put it into reverse its like it is in netural. The car shifts hard from 1 to second usually will shift from first to second if i let up on the gas
Sep 22, 2007 at 2:27 AM
JMCBRIDE1979
hard shift from 1st to 2nd is your valve body.is your service engine soon light on if so have the codes checked.
Dec 31, 2008 at 9:46 AM
BRIAN 1
  • 1,030 POSTS
the reverse reation sun shell is stripped,very common problem.there is an updated sun shell for this vehicle.trans has to torn down to fix.
Dec 31, 2008 at 10:49 AM
