1992 Oldsmobile Cutlass Ciera Stalls at Stop
IF they tested it when it was not happening, it won't matter........cause it isn't happening.
IF they tested it when it was happening, they should have kept going after an ignition problem.
My "GUESS" is a bad ignition module. But I have seen fuel pumps do similiar.
Suggested Repair
Test fuel pressure while the stall is occurring, not only when the car runs normally. If pressure is good, pursue an ignition fault; the ignition control module is the leading suspect, though a fuel pump can cause similar symptoms. A starting-fluid spray into the throttle body when it stalls can help distinguish loss of fuel from loss of spark.
Conversation Summary
A 1992 Oldsmobile Cutlass Ciera with a 3.3L six-cylinder starts and drives normally, then stalls when coming to a stop after a short drive. It restarts but stalls again in Drive until it sits briefly, then runs well for another short distance and idles fine. A shop reported no fuel problem and replaced the spark plugs. The expert said those tests only count if done during the failure and guessed a bad ignition module, while noting a fuel pump can act similarly. Another comment suggested a dirty throttle control and trading the car, which the expert rejected as more expensive.
