Stuck thermostat??
OLDSMOBILE
GREEKGUY7
  • 7 POSTS
I have a 1980 Olds Cutlass 260V8 rear wheel drive. Wife just got home after a long drive in 90 degree heat and noticed it was leaking coolant from the overflow tank when she parked it. I opened the hood and the overflow reservoir was all the way to the top! It was at the proper level the other day.
After waiting 15 minutes, I restarted it and the reservoir tank completely emptied into the radiator but I noticed the upper radiator hose was being sucked/collapsed closed unitl I shut her off. The hose was not collapsed when I originally opened the hood and noticed the coolant was all the way to the top of the reservoir. Any ideas besides the thermostat stuck closed??? THANKS!!!
Aug 28, 2007 at 9:58 AM
[quote:40b063bf5f="greekguy7"]I have a 1980 Olds Cutlass 260V8 rear wheel drive. Wife just got home after a long drive in 90 degree heat and noticed it was leaking coolant from the overflow tank when she parked it. I opened the hood and the overflow reservoir was all the way to the top! It was at the proper level the other day.
After waiting 15 minutes, I restarted it and the reservoir tank completely emptied into the radiator but I noticed the upper radiator hose was being sucked/collapsed closed unitl I shut her off. The hose was not collapsed when I originally opened the hood and noticed the coolant was all the way to the top of the reservoir. Any ideas besides the thermostat stuck closed??? THANKS!!![/quote:40b063bf5f]
Change the thermostat and radiator cap and see what happens
Aug 28, 2007 at 11:24 AM
