1990 Oldsmobile Cutlass Supreme Idle Stall
OLDSMOBILE
TWOHIT
Ok where to start I have a 1990 olds cutlass sup. with a 2.3 HO out of a 92 achiva with about 30,000 on the new motor. Now the problem i have been haveing truble with idle mainly. it will idle up and down a bit in netural/park but when i put in gear it will stall after a few min running unless i keep my foot on the gass a bit. i also have truble starting it. it will go to start but in mid turnover it will stop and if i do it a few times it will back fire on me. also when i have it running my rpm gauge which is a digtial read out will flicker all the way up a few times and when it does i can feel the car shutter a bit then it will die. i have had this car in and out of the shop and no one can tell me what it is. i have spent way to much on this car to just give up. i just repalced the head gasket 6 months ago and have had this trouble every since then and a bit before. but before the head gasket went the idle was way to high. i have replaced tps, map,O2,IAC,new igiton coil, and igiton control modual. and still have all this trouble. i was just told that it might be timing or a Torque Converter Lock Up Solenoid what ever that is. so if u can give me any help let me know or have any more ?s just ask
Jul 18, 2007 at 11:26 AM
SERVICE WRITER
  • 9,123 POSTS
Pulling a code from the computer may help. I can say that I have seen many quad 4 motors that have ingition coil housing problems. When done, the coil boots should be replaced also.
Jul 19, 2007 at 12:46 AM
TWOHIT
the only code i get is for a trans switch and repair shop says that it has nothing to do with the way its running but im not sure now that i seen some thing about that lock out thing for the trans and coil pack is new. i just forked out 600 some dollers for nothing cuz my car still runs like crap
Jul 19, 2007 at 9:42 AM
SERVICE WRITER
  • 9,123 POSTS
(I don't know that I may be much help on this), other than the ignition coil housing and boots that I mentioned. The 2.3 was a (not so) funny engine. There are different strategies you can take if your doing this yourself. If timing is in question, check it. Checking spark is a little more difficult on this one because of the coil over plug set-up. I have seen so many of those coil housings be a problem and cause your symptoms however. I lean towards a spark problem on this.
Jul 19, 2007 at 9:07 PM
Suggested Repair
Inspect the ignition coil housing and replace the coil boots, then verify spark and check timing. The transmission switch code is likely unrelated to the running problem.
Conversation Summary
A 1990 Oldsmobile Cutlass Supreme with a swapped 2.3 HO engine hunts at idle, stalls in gear, is hard to start, backfires, and shudders as the digital tach flickers. The owner replaced the TPS, MAP, O2, IAC, coil, and ignition control module after a head-gasket job, and the only code is a transmission switch. The expert leans toward a spark problem from a faulty coil housing and worn boots, and suggests checking timing if it is in question.
