Should the Fan 1 Relay Control Circuit be changed
NOTHAPPY
  • OLDSMOBILE
I have a 1998 Oldsmobile Achieva with a 3.3 engine. They just replaced the radiator the day I picked it up my check engine light was still on I took it back up there and they told me it was nothing. I took it to Auto Zone and they told me what it was. Should the Fan 1 Relay Control Circuit been changed with the replacement of the new radiator?
Monday, July 23rd, 2007 AT 2:34 PM
CLY
  • 308 POSTS
"Should the Fan 1 Relay Control Circuit been changed with the replacement of the new radiator?"
No.I would check all your fuses with a test light for best results. I would also check and make sure that they plugged the fan or fans back in all the way. If all that checks out ok you may want to try and replace the #1 fan relay.
Cly
Monday, July 23rd, 2007 AT 6:45 PM
