outside air temperature sensor
OLDSMOBILE
JOYMOSSMILLER
I have a 98 Olds Silhouette van. There is a digital readout inside that gives the outside air temperature. The reading is not accurate, however; not even close to the actual outside temperature. One dealer said it would cost about $400 to have it repaired. Is this a reasonable estimate of the cost? I am a mom and a schoolteacher and know nothing about cars. Thank you for your help.
Jun 13, 2006 at 2:10 AM
THDRBIRD10
[quote:191bc46cb5="JOYMOSSMILLER"]I have a 98 Olds Silhouette van. There is a digital readout inside that gives the outside air temperature. The reading is not accurate, however; not even close to the actual outside temperature. One dealer said it would cost about $400 to have it repaired. Is this a reasonable estimate of the cost? I am a mom and a schoolteacher and know nothing about cars. Thank you for your help.[/quote:191bc46cb5]
Jul 26, 2007 at 4:56 AM
ROCKWOOD84
  • 103 POSTS
the sensor is located in front of the radiator passenger side halfway down little grey sensor two wires going to it
Jul 29, 2007 at 7:03 PM
THDRBIRD10
[quote:3a96ea2a7a="rockwood84"]the sensor is located in front of the radiator passenger side halfway down little grey sensor two wires going to it[/quote:3a96ea2a7a]
If this is replaced, should the problem be solved??
Jul 30, 2007 at 11:21 AM
