Hello, well I checked theO2 sensor last night, it's within specs. I put my vacuum tester on, and I got 18-19 pounds, but fluctuatin between 18-19. I did the propane test for the manifold gasket leak, no change in idle. I cleaned out the IAC valve, no change. I checked the torque of the throttle body bolts, all were good. I guess next I check the intake manifold bolt torque.
I did notice something wierd to me. It got dark out and I was looking at the plug wires to see if I was getting a spark leak someplace none foud. I did see a small purple spark continuously jumping from a bolt next to the water pump, right to the pully. I have never seen that before. Unless this is friction from the belt grounding?
Feb 22, 2007 at 9:32 PM
