1974 Oldsmobile Cutlass Dies When Key Released
OLDSMOBILE
JPAULIN
I HAVE A 74 OLDS CUTLASS 350, WITH A HOLLY 600 4 BBL CARB. THE ENGINE HAS BEEN BORED TO 30 OVER, CRANK TO TO 10 UNDER AND HEADS SHAVED 10 UNDER. THE PROBLEM IS IT CRANKS AND WANTS TO START BUT DON'T. IT STARTS WHEN I TURN THR IGNITION KEY TO START POSITION AND HOLD IT THERE. WHEN I RELEASE THE KEY, IT CUTS OUT. I HAVE CHECKED EVEYTHING I CAN THINK OF. I HAVE SPARK AND FUEL TO THE CARB. I JUST REPLACED THE IGNITION SWITCH AND STILL THE SAME PROBLEM. THE IGNITION LOCK SEEM TO BE OK, THERE IS NOT MUCH PLAY IN THE LOCK. DON'T KNOW WHAT ELES TO TRY.
Jul 21, 2007 at 6:15 AM
ROCKWOOD84
  • 103 POSTS
i remember back in the 70s gm products had a black or grey box in the steering column that had rod going from the switch down to it and when the box goes bad the car won't start. pop the covers off the bottom of the column and follow the rod down to the box it has a bunch of wires that plug into it.you can turn the key and the rod should move as you turn the key. thats the only thing i know that could be the problem. let me know
Jul 29, 2007 at 8:26 PM
Suggested Repair
Inspect the steering-column ignition switch (the black or grey box at the bottom of the column) and the actuator rod from the key lock. Remove the lower column covers, confirm the rod moves when the key is turned, and check the wiring plug at the switch. A failed column switch can power the starter in start but drop ignition power when the key returns to run.
Conversation Summary
The owner of a 1974 Oldsmobile Cutlass 350 says the engine cranks and runs only while the key is held in start, then cuts out when released. Spark and fuel are present, the ignition switch was replaced, and the lock has little play. An expert points to the GM steering-column ignition switch box and its actuator rod as the likely cause.
