Olds 98 stalls
1998 OLDSMOBILE
STEVEASCA
My 1985 Olds 98 V 6 Fuel injected with 112,000 miles will run only for short periods I have changed plugs modulator cap rotor and coil. all to no great differance. I am unshure how to ck fuel pressure but I found anouther problem the Alternator is only charging 11.35 volts could that cause the car to stall.
Feb 16, 2007 at 11:49 AM
CHEVY22
  • 1,375 POSTS
on the fuel rail there is a schrader valve , if you dont know what it looks like , its like a valve stem with a black cap on it , get youself a fuel pressure guage and check the pressure and see if it holds or falls and get back to me
jim
Feb 17, 2007 at 9:43 AM
