olds.
OLDSMOBILE
FRISKY
olds intrigue, 2001 98,000 3.5
had head gaskets replaced, thermostat replaced, radiator replaced, had heater core flushed, now car over heats with standard thermostat. mechanic drilled a small hole in the thermostat now car runs to cold. does not reach the quarter mark on heat gauge. CAN YOU PLEASE TELL ME WHY THE MECHINAC DRILLED A HOLE INTO THE THERMOSTAT ? AND WHY THE CAR IS NOT PUTTING OUT HEAT? water pump was checked but not replaced.
thank you hope to hear from u soon
frisky
Jan 19, 2007 at 8:04 AM
CLEAVAGE4U
  • 69 POSTS
Sounds to be that that ol boy just didn't know what he was doin. Daddy says if the thermastat can't seal, then it just miaswell be stuck open. I guess he fixd the overheatin didn't he? An Maybe he just shoulda tried a new thermastat. Daddy says that sometimes you get a bad one even though it's new.
Daddy wants to know if the heads got shaved an ceacked for cracks or pressure when y'all had em off?
I didn't know know those heads could even grow hair. That must be why they callem Heads!
UUUHHHH, How Frisky are ya? :wink:
Jan 19, 2007 at 8:11 AM
FRISKY
they sent the heads out to be milled both sides and checked for cracks. if u have any other ideas please let me know thanks alot
frisky
Jan 20, 2007 at 1:56 AM
