1996 Oldsmobile Bravada No Power
OLDSMOBILE
NEMESIS
hi i have a 1996 oldsmobile bravada, 4.3Li with 114.000 miles. the problem i am having with my car is that i am not getting any power to the entire car! i recently replaced the head gaskets. but since after i reassembled the motor i have not been getting any power,but i think this happened before the gasket replacement. the battery has charge (tested @ 12.73 volts). i checked the fuse box inside of the car and it is dead no power at all? the instrament cluster does not work, inside lights, horn,break-lights, wipers , door chime, nothing? things that does not even have anything to do with the engine, i turn the key and nothing. please help. i would like to know where the primary fuse is located, and or the power distribution center? i need help! thanks
May 15, 2007 at 7:38 AM
  • 75,988 POSTS
[quote:8964517110="nemesis"]hi i have a 1996 oldsmobile bravada, 4.3Li with 114.000 miles. the problem i am having with my car is that i am not getting any power to the entire car! i recently replaced the head gaskets. but since after i reassembled the motor i have not been getting any power,but i think this happened before the gasket replacement. the battery has charge (tested @ 12.73 volts). i checked the fuse box inside of the car and it is dead no power at all? the instrament cluster does not work, inside lights, horn,break-lights, wipers , door chime, nothing? things that does not even have anything to do with the engine, i turn the key and nothing. please help. i would like to know where the primary fuse is located, and or the power distribution center? i need help! thanks[/quote:8964517110]
Look for the fusible links-maybe at the starter
May 19, 2007 at 10:48 PM
Suggested Repair
Inspect the fusible links, possibly located at the starter, for an open circuit that would cut power to the entire vehicle.
Conversation Summary
A 1996 Oldsmobile Bravada with a 4.3L engine has no electrical power anywhere despite a battery reading 12.73 volts. The interior fuse box, instrument cluster, lights, horn, brake lights, wipers, and door chime are all dead, and turning the key does nothing. The owner recently replaced the head gaskets but believes the no-power issue may have started earlier. The expert recommends checking the fusible links, possibly at the starter.
