2004 Oldsmobile Alero No Crank
OLDSMOBILE
JEFFROHOTROD
  • 31 POSTS
I am working on a 04 olds alero 3.4 50,000 miles. The car ran just fine but after killing it it won't start back when you try to turn the key over it doesn't crank, click or anything its like you don't even have a battery in or something. The battery is brand new all the fuses are good. Could it be the ignition switch or what? Thanks
Aug 28, 2007 at 6:49 AM
  • 75,988 POSTS
[quote:300d0a621c="jeffrohotrod"]I am working on a 04 olds alero 3.4 50,000 miles. The car ran just fine but after killing it it won't start back when you try to turn the key over it doesn't crank, click or anything its like you don't even have a battery in or something. The battery is brand new all the fuses are good. Could it be the ignition switch or what? Thanks[/quote:300d0a621c]
Could be the ignition switch/neutral safety switch/starter relay and starter.
Aug 28, 2007 at 11:26 AM
JEFFROHOTROD
  • 31 POSTS
It turns out it was the pass lock sensor. I can reset the pass II system and it starts right up.
Sep 14, 2007 at 3:42 AM
PENGUIN66
I am currently working on a 04 Alero witht similar problems. No cranking when the key is turned. The PCM is not sending the ground to turn on the starter relay. Does the pass-lock do this? because I thought the pass-lock only cut injectors? I also cannot communicate with any of the modules. The PCM has already been swapped with another. Have any help?
Feb 14, 2009 at 5:42 AM
Suggested Repair
Check the Passlock sensor and reset the Passlock II system. Also consider the ignition switch, neutral safety switch, starter relay, and starter if the no-crank condition remains.
Conversation Summary
A 2004 Oldsmobile Alero 3.4 that had been running would not crank, click, or respond after shutdown despite a new battery and good fuses. An expert suggested the ignition switch, neutral safety switch, starter relay, or starter. The owner later reported that the Passlock sensor was the cause and that resetting the Passlock II system allowed the car to start. A second owner described a similar no-crank Alero with no module communication and asked whether Passlock controls the starter relay, but that question was not answered.
