location of signal flashers
OLDSMOBILE
ROBERT JESSEN
I have a 92 cutlass ciera s with 115,00 miles. 6 cyl, four door. I am unable to locate the turn signal flasher for replacement. even a goodyear shop was unable to find ti with a print out from their own data base, wa shown to below and to the left of fuse box. behind lower dash panel
Jun 30, 2007 at 2:17 PM
2CARPRO JACK
  • 11,533 POSTS
It is behind the right side of the dash , behind the fuse block,plugs into the back if I remember correctly
Jul 1, 2007 at 1:48 AM
ROBERT JESSEN
[quote:87041c39f4="2CarPro Jack"]It is behind the right side of the dash , behind the fuse block,plugs into the back if I remember correctly[/quote:87041c39f4] thanks of the tip. I removed the lower panel and the glove box interior, but no flasher. I think it must located on another planet with a transponder!
Jul 1, 2007 at 3:02 AM
