Ignition Control --- C3i Distributorless
OLDSMOBILE
CRYPTY
My 1989 Oldsmobile Delta 88 with a standard EFI 3800 V6 engine(189,000 miles) has not even the smallest spark going to the #1 spark plug. My question is: Since this model has the cylinder's "paired" at the ignition coil, (1&4, 5&2, 3&6), is it safe to assume that a defective coil would kill the flow of juice to a minimum of 2 cylinders? (in my case, since plug #1 is dead at the coil, then plug 4 should also be dead if the "coil" is to blame? Furthermore, if plug 4 fires fine, then the control module "is" causing the problem with plug #1?
Apr 29, 2007 at 8:24 PM
  • 75,988 POSTS
[quote:7fde25546c="Crypty"]My 1989 Oldsmobile Delta 88 with a standard EFI 3800 V6 engine(189,000 miles) has not even the smallest spark going to the #1 spark plug. My question is: Since this model has the cylinder's "paired" at the ignition coil, (1&4, 5&2, 3&6), is it safe to assume that a defective coil would kill the flow of juice to a minimum of 2 cylinders? (in my case, since plug #1 is dead at the coil, then plug 4 should also be dead if the "coil" is to blame? Furthermore, if plug 4 fires fine, then the control module "is" causing the problem with plug #1?[/quote:7fde25546c]
So much of the Computer Command Control Ignition distributorless system
Could be the ICM-I ran into a few of them involving the coil too!.
Apr 29, 2007 at 8:33 PM
