Heater A/C control problem
OLDSMOBILE
JAL9626
I have a 1988 Oldsmobile Cutlass Ciera with about 130,000 miles. It has the V6 and is an automatic. A few months ago, I was having problems with the heater / A/C. It wasn't blowing out the correct selection. I discovered that the vacum hose was not connected and I reconnected it. Everything worked fine until about two weeks ago. The fan selection (low, medium, high) stopped working. The temperature and selection for where the heat / A/C comes out still works fine, but it will only blow out minimal amounts of air from the appropriate selection and temperature. Could it be the dash control, blower motor or something else? Please help, it is starting to get cold here and I need a more heat.
Nov 26, 2007 at 7:03 PM
2CARPRO JACK
  • 11,533 POSTS
Most likely the speed resistor. Should be located in the plenum near the blower motor.Follow blower power wire back to the resistor
Nov 27, 2007 at 9:39 AM
