Good battery but wont crank or take jump, lights dim
OLDSMOBILE
BMAC
1993 Oldsmobile Cutlass Supreme SL, 117,000 mi, V6 3.1, Florida
Won't start and couldn't jump. Clicked, cranked slow but not over. Inside lights dim and/or flickering. Removed battery(Diehard) for testing. Walmart said it's fine. Figured can't be, over to Sears. It tested good there too. Nothing it needed.
Cleaned terminals and reconnected. Still the same. Will check battery cables. My guess is the starter?
Recently car has been leaking or burning transmission fluid, not sure yet. Was getting significant white puff at start up after recent quickie oil change. They overfilled and I had to drain anyway and refill. Also noticed recent hesitant start ups when hot.
Oct 27, 2007 at 2:26 AM
BLACKOP555
  • 10,386 POSTS
since the battery checks out then i would take the starter in and have it tested. if that is not the problem check the starter relay.
Oct 27, 2007 at 2:35 AM
