2000 alero 4 cyl. my ets light and trac off light come off and on. when they do service engine light comes on also. Whats up? Thanks
Nov 25, 2007 at 10:44 AM
TECH1
MEMBER
The reason for the trac off and ets light is because of the check engine light on the oldsmobile alero. When the pcm (powertrain control module) sees a problem with some engine control systems, it will disable the traction control because it does not have the correct data to control traction.
Greatautohelp.com
Dec 2, 2007 at 4:15 PM
