Dim head Lights
OLDSMOBILE
ALBIN
I have a !994 cutlass supreme oldsmobile special
edition (se) mileage 1416330. When i turn my
night lights on they go dim and i can not hardly see
the road at night. The car starts to slow down hardly driving. The Battery gauge goes very low below 13
almost 9 and 18 is the max. At day time it stays at
13 all the time, but i feel the car running slow and
spending to much gas. the engine is a 3.1ltr. 6 cyln
but it was not spending so much gasoline when i bought it 4 months ago everything else i guess is fine
i changed wire and sparkplugs . But still have the same problem i was told it was electric problem and afterwards i was told it was a mechanical problem i
got a new alternator and still having the same problem the car is charging find, is not the battery
is in good conditions not unless i should buy a new one the one i have is not that old. please help me
if you can. Thanks.
Jul 9, 2006 at 11:34 AM
HOLLYSCAR
  • 5 POSTS
It sounds like you have a problem with the regulator and the alternator. Was your alternator rebuild? Was is the amps on the alternator.
Nov 16, 2006 at 2:00 PM
RYANUNI
  • 34 POSTS
I Absolutely agree, have your alternator checked. My 1994 Cutlass had a similar problem, volt meter read a little low while driving under a full draw, I assumed it had something to do with the the new sound system I had installed. It operated normally for months till all at once the alternator died. I ended up changing the alternator along a country road at midnight in a zero degree Iowa winter NOT FUN. Have it tested before it is too late!
Jan 25, 2007 at 3:52 PM
