1988 Oldsmobile Cutlass Surging Idle
Couple notes: Don't confuse being a female with being oblivious...it just ain't so. Your smarter than you think you are :wink: And your going after it, that alone calls for respect.
It sounds like there is a vacuum leak. However I may not be clearly understanding you.
Is this right?
When you start the car it idles very high? stalls, when you put it in gear.
The MAF is possible, if may have become contaminated, check for an oily substance in it. The can be cleaned with an electrical component cleaner spray.
More apt to think the IAC motor, after thinking about it-I am a service writer, not a tech :shock: . This component can also be cleaned. I thinkI was off about the vaccum leak :oops:
What size engine do you have? 3.1?
Can you have the codes pulled from the computer?
Sounds like a bit of a fuel/fuel control issue. Try this. Disconnect the O2 sensor and try to restart. If the engine starts and runs ok, then theres your baby. If not, then some more questions are in order. Have you verified that all the vacuum lines/hoses are attached and not broken? Try disconn the coolant temp sensor and restart, see if the condition changes. Do you just have a code reader? Or a scanner that can view data stream? Or are you jumpering the A/B at the Data Connector?
Let us know!
Chris
Suggested Repair
With no stored codes, inspect and clean the idle air control (IAC) motor and recheck the MAF for contamination. Confirm vacuum hoses are intact. As a test, disconnect the oxygen sensor and restart; if that does not change the surge, disconnect the coolant temperature sensor and compare. Have live data scanned if the car must be towed.
Conversation Summary
A 1988 Oldsmobile Cutlass with a 3.8L surges and jerks at idle without throttle input, backfires, stalls in gear, and later will not idle. The fuel pump, MAF, and crankshaft sensor were replaced earlier; the MAF showed no oil and no codes were stored. Experts suggested an IAC problem or fuel-control issue and recommended checking vacuum lines and testing by disconnecting the oxygen and coolant temperature sensors. The owner planned those checks but had not reported results.
