Climate Control Blower
OLDSMOBILE
SNOSAINT
  • 76 POSTS
1991 Oldsmoble Custom Cruiser 5L V8 120K miles. Electronic Climate control.
I shut off the car & the blower motor kept running.
This happened repeatedly, so i disconnected the battery & removed the kick panel where the blower is located. I reconnected the battery & the blower started running, so i pulled the relay. Blower kept running! I disconnected the blower connection & disconnected the battery again. I reconnected everything & now the fan doesn't work at all. The relay tests fine. The Electronc head shows no faults, all controlls function, just no fan and a test light connected to the fan power lead terminals did not light. Service book mentions a power module & connectors. I don't know where it is or what it looks like. Am i thinking allong the right lines & where are these located, how do i get to them?
Sep 9, 2007 at 1:13 AM
SNOSAINT
  • 76 POSTS
The blower control module is next to the blower motor under the dash kick panel. undo the two power connectors, remove the 3 screws & it drops out. The module is mounted on a heat sink with 2 screws. you can also remove the face plate. The modules are interchangable with other climate control equiped vehicles, some even have fewer connectors but may still work. try & match the id numbers or search for cross refference parts to know which makes & models might have what you need
May 25, 2009 at 12:10 PM
SNOSAINT
  • 76 POSTS
Some of the vehicles with usable blower control modules have them mounted in different locations, many are under the hood in the AC area near the firewall. Look for the connectors, the panel may be differently shapped, but all you need is the module or the module with the heatsink. You can swap the face/mounting panel easily.
May 25, 2009 at 12:16 PM
SNOSAINT
  • 76 POSTS
some part numbers that have worked for me:
(imprinted on the chip/module)
16061602 stk 6994j
16173869 stk 6994jh
May 25, 2009 at 12:19 PM
SNOSAINT
  • 76 POSTS
a crossover number that i found that is supposed to work: 12484912
May 25, 2009 at 12:21 PM
SNOSAINT
  • 76 POSTS
It is 2 yrs later & i have a similar but different problem ihave now posted about. I hope all of this helps others with similar issues.
May 25, 2009 at 12:23 PM
