1977 Oldsmobile Delta 88 Hard Steering
OLDSMOBILE
LONEWOLF8
helo again the battery works and the car has more power then ever. it is working great. i have another question about my 77 olds delta 88. the steering feels funny like it can't steer right. it feels difficult when i turn . the steering fluid is low and that might be the reason it doesn't turn right, i mean it turns both ways. it's just difficult.
Oct 23, 2007 at 2:00 PM
SERVICE WRITER
  • 9,123 POSTS
Certainly fill the fluid.
IT may be a hydrolic problem as in the pump or rack, or it may be a mechanical problem such as strut mounts, ball joints etc.
Does it make any noise?
May need to jack it up and disconnect the outer tie rods and see if the wheels are still hard to turn, this will eliminate the rack/pump, if it doesn't turn easy. If it does, then your into a hydrolic problem.
Oct 23, 2007 at 2:07 PM
Suggested Repair
Fill the power steering fluid first. If steering stays hard, note any noise and isolate a hydraulic problem (pump or rack) from mechanical binding such as strut mounts, ball joints, or tie rods by raising the vehicle and disconnecting the outer tie rods to see whether the wheels still turn hard.
Conversation Summary
The owner of a 1977 Oldsmobile Delta 88 says the car runs well but steering feels difficult in both directions and the power steering fluid is low. The expert advises filling the fluid and says the cause may be hydraulic, such as the pump or rack, or mechanical, such as strut mounts or ball joints. They also ask about noise and suggest jacking the car and disconnecting the outer tie rods to see if the wheels remain hard to turn.
