1989 Oldsmobile Cutlass Calais Spark Plugs Fix
OLDSMOBILE
MARIONICANOR
Where are the spark plugs on a 1989 cutlass calais quad 4 engine?
Mar 20, 2007 at 12:31 PM
SERVICE WRITER
  • 9,123 POSTS
There is a coil housing cover that has to be removed in the center top of the engine, 4 bolts I think, it comes off by pulling straight up. They are under the coil housing, which boots are located between the housing and plugs.
Mar 20, 2007 at 12:33 PM
Suggested Repair
Remove the coil housing cover at the center top of the engine (about four bolts) by pulling it straight up. The spark plugs are underneath, with the boots between the housing and the plugs.
Conversation Summary
The owner of a 1989 Oldsmobile Cutlass Calais with a Quad 4 engine asked where the spark plugs are located. The expert explained that they are under the center-top coil housing cover, which comes off after removing the bolts and pulling the cover straight up; the boots sit between the housing and the plugs.
