1996 Oldsmobile Ninety-Eight No Panel Air
I found the temperature blend control behind the glove box. I also found several colored vacuum tubes going in it as well. I have not torn the dash apart yet. Is this appartus where the colored tubes go in where the air direction is controlled? Should I assume the other end of those tubes goes to the control head on the dash?
I do have the electronic climate control. I think its working properly as the air direction responds slightly to when i change it, but pretty much air comes out the defroster and floor no matter what you choose. I can try the voltmeter, however.
I do appreciate your help as I have not worked with automatic climate controls before.
I am not really wanting to tear out the entire dash to get to the vacuum motor. Any gut feelings on which is the more likely? Since nothing really moves at all I lean on the programmer box, but again I am not that experienced with these things. Also how do you get that darned vacuum plug off the programmer? That long screw makes it tough on a standard socket.
Anyone have thoughts or comments?
The only problem I have now is that the temperatures blinks for about a minute when the car comes on. It runs from full hot to full cold, then to whereever its set for during this time. After that, operation is fine. I guess I must have done something it didn't like. I don't know if this was a pre-existing problem or not but the passenger side is colder than the driver's side during a blended temp. Both sides still go full hot and full cold. Strange car that I have.
Anyone have any ideas?
thanks
jim
oh and leave some feedback if you were happy with your help , we all donate our time here helping others free of charge
thanks
jim
Suggested Repair
The mode problem was caused by crimped vacuum ports at the programmer connector, which blocked vacuum to the mode motors. Open each port with a thin pin and blow them clear, then confirm vacuum reaches the motors. For the startup temperature sweep and uneven blend, disconnect the battery negative cable to clear a possible fault; if both blend doors still move, suspect the climate control head.
Conversation Summary
A 1996 Oldsmobile Ninety-Eight with electronic automatic climate control heated and cooled, but airflow stayed at the defroster and floor instead of the panel vents. Vacuum was present at the programmer, and the owner found the connector ports crimped shut so no vacuum reached the mode motors. Opening the ports with a thin pin and compressed air restored vent operation. Afterward, the temperature display blinked and swept from full hot to full cold for about a minute at startup, and the passenger side was cooler than the driver side in blend mode. The expert suggested disconnecting the battery negative cable and, if both blend doors open, checking the control head.
