1997 Oldsmobile Aurora Uneven A/C
OLDSMOBILE
PERRYDOG
I have a '97 olds aurora 4.0 with 127k. Drivers side A/C is approx. 10 degrees warmer than passenger side. The car has dual climate control. Thru web search I've learned I might have a bad computer unit in the a/c system or a stuck actuator/blend door. How do I determine which? This is a cheap business car for me so I don't care about dual climate control. Can I eliminate the blend door? Where is it located? Is it "upstream" of the heater core? Can I get a cheap replacement computer module if necessary? As of writing this half my interior pieces are laying across my front yard. Would a hand grenade work?
Jul 21, 2007 at 3:32 AM
2CARPRO JACK
  • 11,533 POSTS
A grenade is the easy way out LOL....The blend door is usually at the bottom of the plenum box.I would lean toward a weak actuator motor or possibly something like a pen or the such has fallen down the defroster and is wedged in the door keeping it from closing all the way.Most of the time if it does go cold and hot, the controller is working, just not something on the other end of it
Jul 22, 2007 at 12:23 AM
Suggested Repair
Inspect the blend door at the bottom of the HVAC plenum. A weak actuator motor or debris, such as a pen fallen through the defroster, may be keeping the door from closing fully. If the system still produces both hot and cold air, the climate control module is likely working and the fault is at the door or actuator.
Conversation Summary
A 1997 Oldsmobile Aurora with dual climate control has driver-side A/C about 10 degrees warmer than the passenger side. The owner asked whether the climate control computer or a stuck blend door/actuator was at fault, and where the door is located. The expert said the blend door is usually at the bottom of the plenum and suspected a weak actuator or debris blocking the door; if hot and cold air still change, the controller is probably working.
