99 olds alero sputtering
1999 OLDSMOBILE
TKUINDER
Hello
I have a 99 oldsmobile alero w/ about 135000 miles on it. Recently my car has been sputtering. I'd like to use a different adjective but sputtering is close to what it's doing or maybe I could say it dies out a bit. When I first take off after my car has been sitting for awhile it acts like it wants to die. When I hit the gas it kind of thinks about it for a sec and then decides to go. I've noticed when I'm on the highway and I let off the gas a bit and then hit the gas again to go faster it does this. The weirdest part about it is my Lo Trac light comes on when it does this. I'm not sure what this means. Could it have something to do with the transmission or my the fuel injector?? It seems to be getting worse as the winter goes on. Please help!!
Thank you!!
Mar 1, 2006 at 5:30 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :)
What maintenece has been done? Fuel filter, plugs, wires, air filter been replaced recently? Justy mioght be tune up time. Try some fuel injector cleaner in a tank or 2.
Good luck and let us know.
Mar 1, 2006 at 9:26 AM
2CARPRO JACK
  • 11,533 POSTS
Post in the correct forum please
Thanx
Mar 1, 2006 at 9:48 AM
JPAM
  • 307 POSTS
gettin it moved.. :D ..
Mar 3, 2006 at 7:02 PM
