2002 Oldsmobile Bravada Warm Hesitation
2002 OLDSMOBILE
LORILAACY
I just bought my 2002 Olds Bravada, I-6,4.2L Vortec, 65,000 miles. Just after the warranty period expired, my car started missing or stuttering, just during low demand driving, say at 40mph or so, when not really accellerating. Then this weekend, after a long driving trip, it started doing it on the highway, too. Seems to be getting worse, especially after car warms up. Tried dropping it into 3rd, didn't do it then. Any ideas?
Feb 6, 2007 at 3:26 AM
SERVICE WRITER
  • 9,123 POSTS
It needs troubleshooting, we can have changing possible parts, but without testing, it could get expensive. IS the fuel filter original? IF so, the fuel pump may be weak from trying to push fuel through a plugged filter.
May want to check the codes in the computer as it may lead us to the promised land. :wink:
Feb 6, 2007 at 3:51 AM
LORILAACY
I had the fuel filter changed, it still does the same thing...only after the vehicle is fully warmed up. Kind of a jerking, or hesitation, doens't do it when coasting.
Feb 9, 2007 at 2:29 AM
SERVICE WRITER
  • 9,123 POSTS
Feb 9, 2007 at 12:16 PM
LORILAACY
Had the codes checked, nothing showed up....my nephew is in auto tech school....says he thinks it is the transmission not "locking" into overdrive, slipping in and out. Would a transmission flush help this if this is the problem? He seems to think so.....but I realize he is a student....(he also says new filter along with flush)
Feb 12, 2007 at 5:17 AM
SERVICE WRITER
  • 9,123 POSTS
Well, we are all students of auto repair regardless of experience :wink:
If you haven't replace the transmission filter, he is giving you good advice. I don't know that will or won't help, but it is something that should be done regardless. If it takes care of it, it's bonus.
Feb 12, 2007 at 8:12 PM
Suggested Repair
Replace the transmission filter as recommended service. A transmission flush may or may not stop the warm hesitation, so do not treat it as a confirmed fix; the fuel filter was already replaced and no codes were stored.
Conversation Summary
A 2002 Oldsmobile Bravada with the 4.2L engine hesitates or stutters under light load and later on the highway, mainly after it is fully warm, and does not do it while coasting. The fuel filter was replaced and a code check found nothing. A student suggested the transmission was slipping in and out of overdrive and recommended a flush with a new filter. The expert said replacing the transmission filter is worthwhile maintenance but could not say whether it would fix the symptom.
