97 Oldsmobile Regency V6 3.8L. serpentine belt replacement.
1997 OLDSMOBILE
IRA45
My question is do I have to take off the motor mount and support in order to replace the belt or is there another way to install the new belt?
Jul 13, 2006 at 3:39 PM
XOWEY
  • 113 POSTS
I don't believe you have to take the mount off this one, just remove the lower spacer. :wink:
Jul 19, 2006 at 1:22 AM
KINGSTAR
  • 5 POSTS
i just replced the belts on my 97 lss. i had to loosen the top support bolt beside the water pump pully and pry the engine over about 1/2 ". then just slide the belt between the pully and the mount. i had to use a second person.
Oct 29, 2006 at 2:09 AM
