96 oldsmobile cierra
1996 OLDSMOBILE
JCOPPI5
i have a 96 oldsmobile cierra that was running rough and i changed the spark plugs and did routine mantinence. when i got done the oil light came on and didnt shut off i checked my oil filter and it was still dry does this mean i need a new oil pump and if so what should i look for when i have the oil pump out to decide if thats the problem?
Oct 18, 2007 at 3:46 AM
JWALTH02
  • 180 POSTS
What kind of noise is it making when you turn it on? Is it a high pitched squeal, low whine, minor explosion? Also how many miles and size and type of engine you have to proceed. Thanks
Aug 2, 2007 at 3:34 PM
TRLWRIDGERUNNER
  • 5 POSTS
[quote:6f8aee8408="jwalth02"]What kind of noise is it making when you turn it on? Is it a high pitched squeal, low whine, minor explosion? Also how many miles and size and type of engine you have to proceed. Thanks[/quote:6f8aee8408] It is a high pitched squeal.It has 114,991 miles on it and a 2.0L-2V engine
Aug 3, 2007 at 11:55 AM
JWALTH02
  • 180 POSTS
And this only happens when you turn on the a/c not any other time? Sounds like your compressor pulley is giving out.
Aug 4, 2007 at 2:15 AM
