96 aurora "twilight sensor" problem???
1996 OLDSMOBILE
MOZEZ
just wanted to know why my twilight sensor running lights. dont work anymore i've check fuses and everthing. it does not come on when i use it. maybe i've missed something.
it a 96 olds aurora 108k. please help? thank you MOZEZ
Feb 27, 2007 at 10:13 AM
BRUCE HUNT
  • 3,754 POSTS
Let me put it to you this way. No one responded to the posting so I would like to give it a try. Do you know why the cat and the o2 sensors are on the vehicles. They help keep the air clean for the next generation of people on the earth. You have changed the back pressure on the system and your cars computer is probably starting to have problems with adjusting the fuel mixture. I do know that a bad or missing O2 can be really slow to manifest problems. I have seen the lower one be broken and yet the car ran fine for 2 -3 thousand miles with no problems. Then one day it started to faulter at stops and got a little worse as time went by. Replaced the O2 and within 20 miles the problems were eliminated.
Jan 16, 2007 at 6:16 AM
CHEVY22
  • 1,375 POSTS
this could be one of several problems , try this there is a photcell on the dash should look like a black dome size of a quarter , cover it with paper and see what comes oon and what doesnt ,
let me knwo jim
Feb 28, 2007 at 7:12 AM
