A quick way to check if your engine is locked up is to get out your handy 3/4" ratchet and socket set, put a socket on your camshaft pulley and try to turn the engine over by hand. Also check the oil filter for any signs of damage, and that it's mounted correctly. When you try to start it do you hear any noises from the starter, like the solenoid engaging or the motor spinning?
SPONSORED LINKS
Monday, March 19th, 2007 AT 3:11 AM
