94 Olds Achieva radiator
1994 OLDSMOBILE
MIDNNITE
94 Ods Achieva 3.1L 133thousand miles
I've owned this car for the past 3 yrs. and I'm getting ready to put in the 3rd radiator. The radiators I've had so far... 'bust' in the seam, in the same spot. Do you know the cause of this problem?
Nov 10, 2007 at 12:43 PM
BLACKOP555
  • 10,386 POSTS
check your head gaskets and also try buying a good quality radiator.
it may even be a bad ground not grounding out all the energy but instead grounding it into the radiator causing the coolant to turn acidic eating away the radiator.
Nov 11, 2007 at 12:30 AM
