86 olds cutlass ceira, no fuel thru TBI
1986 OLDSMOBILE
WAHLAH
Have a 86 olds cutlass ceira,2.5 cu in. auto,70,000 actual miles. Have replaced these parts with working parts from another friends car. Fuel pump,TBI unit,fuel pump relay, ECM, distributor. Even used auxilliary tank to put fuel to TBI, still no fuel passes thru the injector. What could I have possibly missed? Is there a way to bypass something to get fuel to flow out of injector. Car runs if u dump fuel in thru throttle body. How would u test for a fuel pulse at TBI? I,m stumped :cry: ,any ideas? :idea: thanks
Dec 17, 2006 at 3:54 AM
HYKNRD
  • 59 POSTS
This might help:
Test for Injector Pulse. Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't responded a Ignition Distributor/Crank Angle Sensor (CAS) or a Ignition Module is most likely your problem.
Hope that helps.Let us know
Dec 20, 2006 at 7:40 PM
AUTO3693
Sounds like I have the same problem as you. What did you find out?
Mar 19, 2007 at 5:01 AM
