2002 Other Oldsmobile Models Connecting trailer lighting dis
2002 OLDSMOBILE
58,000 MILES • 6 CYL • FWD • AUTOMATIC
BJBRISBINE
I am attempting to complete the installation of the trailing wiring. The van came with a factory provided wiring harness "pigtail." I have used bullet connectors to attach the harness to on of two different Hoppy convertor assemblies. The first was the correct converter (as confirmed by Hopkins Mfg tech support) to combine separate turn signal with the brake lights in a flat 4-wire lead. The second was a power tail light converter (separate fused lead to battery and separate ground wire -- provided at no charge to me by Hopkins -- to resolve the following problem. (Neither has corrected it.)
Problem -- when any one of several trailers with flat 4-wire leads is connected to the vehicle and the vehicle is started the trailer lights fail to operate properly and the TCS disabled and ABS warning messages and lamps are activated.
The one variable I have not yet tried is to eliminate the OEM trailer lighting pigtail and splice directly into individual lamp wires. I'd prefer not to do this unless absolutely necessary as the OEM connection is much more convenient.
Any suggestions for troubleshooting and fixing this problem.
Aug 19, 2008 at 8:00 AM
MASTERTECHTIM
  • 4,750 POSTS
what colors are athe wires your using from the factory harness? do they match up with the pigtail you have? did you try using a test light to confirm the wires from vehicle are the right ones? i have never run across any problems before.
Aug 19, 2008 at 12:24 PM
BJBRISBINE
Factory provided trailer lighting pigtail (plugs into main harness near air leveling compressor at left rear) has SIX wires:
Green - RH turn
Yellow - LH turn
Brown - Tail
Black - Stop
Orange - Power (even with ign off)
White - Ground
I reconfirmed each using a test light. They match up to the leads on the converters.
Aug 22, 2008 at 4:02 AM
MASTERTECHTIM
  • 4,750 POSTS
first of all what is the exact vehicle you have? if the turn and brake signal are the same bulb then you will need no adapters just dont use the black brake wire. let me know the exact vehicle.
Aug 24, 2008 at 8:01 AM
BJBRISBINE
2002 Oldsmobile Silhouette (van) GLS
VIN 1GHDX03E82D1100XXX
Separate turn signals
Aug 26, 2008 at 11:10 AM
MASTERTECHTIM
  • 4,750 POSTS
ok i found your problem in my schematic. your ground is the black wire and the brake light is the white wire. thanks for hanging in there, i missed your post yesterday. this should definitely fix your problem. let me know
Aug 26, 2008 at 11:54 PM
