2002 Merc Sable-Trans Fluid change
2002 OLDSMOBILE
MSTONE101
I had the dealer do a transmission fluid change and they didn't change the filter. Does that sound normal to you? They extracted the old fluid through the trans cooling hoses. I wish they would've pulled the pan and changed the filter. Also, they charged me for 16 qts of Mercon V fluid. According to a repair manual I have the tranny only holds about 12 or 13 qts. I'll hang up now and listen to your reply. :shock:
Sep 22, 2006 at 7:37 AM
MERCCRUISER
  • 16 POSTS
i would point that number of quarts of tranny fluid to them and get you money back.. and yes it is common for dealships to change tranny fluid without changing the filter, (on newer cars)
Oct 4, 2006 at 9:33 PM
