2001 Other Oldsmobile Models 2001 OLDS SILHOUETE IDLE?
2001 OLDSMOBILE
83,000 MILES • 6 CYL • FWD • AUTOMATIC
BMAX100
HI, I have a problem with my van. When i take off and go like 40 to 50mph and let go of the gas pedal, the van still stays at that speed, unless i apply the brakes, then it takes a little longer to stop. Also, if i'm in a dead stop, and not pressing the gas pedal, the van slowly goes to 30mph, by itself. Other than that, the engine runs perfect, even when in park. I wanted to know if anybody knows what the problem could be? I would appreciate any kind help on this. Thanks.
Apr 25, 2008 at 2:13 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like your cruise control is acting up. take a look and make sure its off
Apr 25, 2008 at 2:27 PM
BMAX100
it's off, and it still does it.
Apr 25, 2008 at 2:35 PM
LEGITIMATE007
  • 5,121 POSTS
you have to check it underneath the hood in the engine compartment. it may be stuck
Apr 25, 2008 at 3:12 PM
BMAX100
doesn't the cruise control, kick on a certain speed? also, how can i tell if it's stuck? thanks.
Apr 25, 2008 at 3:17 PM
  • 75,988 POSTS
The cruise control has to be set to activate it. Find the fuse no.739 10amp in the instrument panel fuse block and remove it this will make it inoperable and see what happens Could also be the throttle position sensor way out of calibration fooling the computer that the engine needs fuel when not needed.
https://images.2carpros.com/forum/automotive_pictures/12900_cruise_1.jpg
Apr 25, 2008 at 6:07 PM
BMAX100
Hi, Thank you for your kind help. One thing i forgot to mention is, when i bought the vehicle yesterday, it was running with the low fuel light on, for about 20mins. We put gas and then drove on the highway to go home, we turned the cruise control on, it worked. Then after 30mins of highway driving, we came to city limits, which was 45mph or less. Then this started happening. I am disabled, with a leg injury, and i live on limited income, and if i take it to a dealership, they might start guessing, and charge me with parts, not needed to be fixed. I would appreciate kindly, if you can help me with this problem. Thank you, again.
Apr 25, 2008 at 7:01 PM
